1988 Chevy Corsica 88 Chevy Corsica -No Start
LOU BARAZA
  • 1988 CHEVROLET CORSICA
  • 6 CYL
  • FWD
  • 10,000 MILES
1988 Chevy Corsica 2.8 V6
Car has spark, fuel pressure didnt have injector pulse from noid light. Replaced ECM, injectors have pulse, fuel pressure good, has GREAT spark, still no start. Pulled out spark plugs which were wet and replaced, still no start.I am suspecting possible crankshaft sensor, but was told if CKS sensor was bad, I would not get injector pulse or spark. Possible timing chain failure?Compression test?
Any help would be great.
Thursday, January 28th, 2010 AT 11:40 PM
  • 109,885 POSTS
If you are getting spark, the crank sensor is good. I would recommend checking timing and compression. Here is a how to check compression:
https://www.2carpros.com/dia/how_to_check_compression.htm
Let me know what you find.
Friday, February 19th, 2010 AT 10:40 PM
