2006 Chevy Cobalt door locks
JJJJ1980
  • 2006 CHEVROLET COBALT
Electrical problem
2006 Chevy Cobalt 4 cyl Front Wheel Drive 50000 miles
My car is continually unlocking on it's own. It's getting worse, the door is already unlocked and you can hear it trying to unlock! I have replaced the fuse, that didnt work. What next? HELP
Thursday, September 25th, 2008 AT 2:37 PM
BRIAN 1
  • 1,030 POSTS
It has been reported that an issue exists that will cause the door locks to cycle when driving and/or become inoperative from the door lock switches. When the condition is present the door locks are inoperative from the switches, however they work normally with the key fobs. (If equipped with Remote keyless Entry)It is recommended that you connect the Tech-2 to the vehicle and look at the door lock switch status (RFA data-list) it should be reading "Idle". If it reads lock or unlock then check for a possible sticking door lock switch and replace as necessary.
Try this. Post back with what you find
Thursday, September 25th, 2008 AT 4:55 PM
