2006 Chevy Cobalt Braking Causes Steering Wheel to Shake
2006 CHEVROLET COBALT
42,000 MILES • 4 CYL • FWD • AUTOMATIC
MSSTANLEY
Recently had a new set of tires put on at a reputable national chain and noticed two weeks later that while braking at highway speed (70mph), the steering wheel shook a bit at the bottom. As I went along further and braked, the shaking became worse and worse until it felt like the front end of the car was shuddering. Took the car to the dealer, who checked out the front rotors, calipers, brake pads/shoes, steering wheel itself and the tires. They said they were stumped, but were going to check to see if the engine was shifting inside during braking. Called the place where the tires were put on and asked if the tires could be causing the problem. They said it was possible that they weren't balanced correctly and to bring the car in. Could it be the tires or does it seem like something else?
Jul 1, 2008 at 8:56 AM
RHALL77
  • 3,361 POSTS
could be the tires out of balance or they just over tighten the wheels when they put the new tires on warping the brake rotors.
Jul 1, 2008 at 9:04 AM
DOCFIXIT
  • 18,828 POSTS
Need to check runout on the rotors ie. check warpage
If the tie gut over tightened the wheel rim after some driving it will warp the rotors and you get the shakes.
Jul 1, 2008 at 9:06 AM
