1998 Chevrolet 1500 Misfire
STOMMER
I have a 1998 1500 with 122,000 miles and 4.3 liter engine. I have a intermitten miss fire, especially in the mornings. I have replaced spark plugs, wires and cap and rotor. I have replaced fuel filter and ran injector cleaner through fuel system. I have tested coil and it test good. Some times I will get Code P330 which is radom miss fire. So far nothing has changed. Please help
Aug 2, 2007 at 4:21 AM
  • 75,988 POSTS
[quote:80cbfa53cd="stommer"]I have a 1998 1500 with 122,000 miles and 4.3 liter engine. I have a intermitten miss fire, especially in the mornings. I have replaced spark plugs, wires and cap and rotor. I have replaced fuel filter and ran injector cleaner through fuel system. I have tested coil and it test good. Some times I will get Code P330 which is radom miss fire. So far nothing has changed. Please help[/quote:80cbfa53cd]
PO300 is normally caused by vacuum leak and bad petrol. check this out then report back.
Your options: you can have the fuel lab tested or use a vac gauge to track the vacuum.
Aug 18, 2007 at 11:37 AM
Suggested Repair
Check for a vacuum leak with a vacuum gauge and have the fuel tested, since a P0300 random misfire is often caused by a vacuum leak or bad fuel.
Conversation Summary
The owner of a 1998 Chevrolet 1500 with a 4.3L engine reports an intermittent misfire, worse in the morning, and a random misfire code. Plugs, wires, cap, rotor, and fuel filter were replaced, injector cleaner was used, and the coil tested good with no improvement. The expert says P0300 is commonly caused by a vacuum leak or bad fuel and recommends a vacuum-gauge check or fuel lab test.
