1995 Chevy Cavalier Rough When Cold
MARTIN T
my 1995 chevy cavalier, with 144,000 miles runs very rough when cold, it runs good after it warms up and starts and runs good when the outside air temp is above approx 60 degrees fahrenheit, the o2 and air intake sensors checked good.
Apr 3, 2006 at 11:00 PM
LOSONE
  • 1,616 POSTS
Change the coolant tempoerature sensor It is near the t-stat housing. It has a yellow wire and either a purple or brown. the yellow color is the most important. Note engine must be cold
Apr 4, 2006 at 8:09 AM
Suggested Repair
Replace the coolant temperature sensor near the thermostat housing. Identify it by the yellow wire and a purple or brown wire, and do the work with the engine cold.
Conversation Summary
The owner of a 1995 Chevy Cavalier with 144,000 miles says it runs very rough when cold but runs well after warming up and when the outside temperature is above about 60°F. The oxygen and air intake sensors tested good. The expert recommends replacing the coolant temperature sensor near the thermostat housing, identified mainly by its yellow wire and a purple or brown wire, with the engine cold.
