1995 Chevrolet Cheyenne Dies on Acceleration Fix
WPONDER3
1995 Chevrolet Cheyenne 6.8 turbo diesel, automatic, one-ton flat bed with approximately 135,000 miles.
Engine had been running fine except on a hard acceleration when it sometimes missed--not seriously but noticeably. The other day, I had driven about 15 miles and started accelerating as I entered a freeway. The engine started heavily misfiring and within 10 seconds, died. It restarted but went only a short distance and died again. I was able to get back home but only after several starts, stops, rests, restarts. No "water in Fuel" light ever came on and fuel filter appeared fairly clean with only the bottom area of the filter even stained. I replaced the fuel filter anyway and it seems to be running OK now but I'm afraid to venture very far until I know what might have been the cause of the problem. Any ideas?
Aug 10, 2007 at 7:16 AM
2CARPRO JACK
  • 11,533 POSTS
Could be a problem with the injector pump ..... or at least one injector due to the miss you describe.They have very high fuel system pressure, I wouldnt suggest doing much testing in that area yourself, probably should take it to a diesel shop
Aug 10, 2007 at 11:11 AM
Suggested Repair
Have a diesel shop inspect the injector pump and injectors. Do not pressure-test the high-pressure fuel system yourself. The fuel filter was already replaced.
Conversation Summary
A 1995 Chevrolet Cheyenne turbo diesel sometimes missed on hard acceleration, then misfired heavily and died after about 15 miles, restarting only briefly. No water-in-fuel light came on, and the fairly clean fuel filter was replaced; the truck then seemed to run normally. The expert suggested an injector pump or injector problem and recommended a diesel shop rather than self-testing the high-pressure fuel system.
