1994 Chevy Cheyenne Brake Lights
114,000 MILES • V8 • 4WD • MANUAL
RAMBIN11X11
Hello, I hope you can help....
My truck has running lights, signal lights, reverse lights but no break lights. It has cruise control on the column with wipers/washer switch. I have replaced the break switch on the pedal. Any thoughts? Could it have something to do with the cargo light?
Thank you and I am awaiting your reply. Help and I will donate!!
Chip R
Sep 4, 2009 at 4:00 PM
  • 110,248 POSTS
WHen you replaced the brake light switch, did you check to see if there was power to the switch?
Nov 3, 2009 at 2:41 AM
DURAN1988
  • 9 POSTS
you might try to trace your wires that come back from your brake lights and see if maybe there is a wire that may be burnt in half...or maybe a ground wire (black) that isn't grounded right. i had this problem with mine and it was a ground wire. good luck
Dec 10, 2009 at 3:38 PM
