1996 Chevy Cheyenne Brake lights not working
1996 CHEVROLET CHEYENNE
STEVE ROBINSON
Brakes problem
1996 Chevy Cheyenne V8 Two Wheel Drive
Could a bad ground wire be causing my brake lights to not work. I have replaced the brake switch. I would also like to know if you could let me know where my ground wires are located at
Dec 28, 2009 at 3:21 PM
MERLIN2021
  • CAR REPAIR CONTRIBUTOR
  • 17,250 POSTS
Bad Ground wires would cause a 1/2 bright condition, more likley to be the circuit boards the bulbs plug into, or a bad multifuntion swtch(turn sg).
Also have you check the fuse?
Dec 28, 2009 at 3:30 PM
