1993 Chevy Cheyenne no fule and no spark
180,000 MILES • 6 CYL • 2WD • AUTOMATIC
DODGECHRIS
the motor will turn over . the rotor is turning. iam not getting any spark at the same time iam not seeing any fuel spraying from the injectors. what could be the problem and or the cause. and what is the solution to fixing it
Dec 10, 2008 at 11:40 AM
  • 75,988 POSTS
Do you hear the fuel pump for 2secs when key at run position?
Check fuel pump inline fuse 20amp and fuel pump relay
No spark-could be coming from the ignition switch ignition circuit-
Dec 10, 2008 at 11:58 AM
