I have a '91 chevy K1500 and recently replaced both head gaskets at two different times. After replacing the first, I got it to start up but oil was leaking from above the exhaust manifold. I replaced the head gasket on that side, both intake mainfold gaskets, and both valve cover gaskets. The leak stopped, but now the engine won't start. The flywheel turns, all lights work, and spark plugs do spark. The only thing that is really wierd is there is nothing coming out of the tailpipe, no pressure, no exhaust. I am not sure what the problem is at this point but I think that might be the key. Any thoughts? I have been working on this project for awhile and really want to get it wrapped up. Thanks in advance!
SPONSORED LINKS
Monday, January 12th, 2009 AT 2:36 PM
