1990 Chevy Celebrity Warm No-Start
My basis for saying the car is not overheating is no smoke, no funny noises etc. the only thing indicating overheating is the water temp needle. I am not loosing coolant. Getting the radiator cleaned and the new neck was a total cost of $65. I did open up the bleeder bolt on top of the engine. I did forget to check the fluid after I ran the car (oops!) But after reading other forums I asked my dad to check the level because it is over at his house at the moment.
For the whole radiator service that they were going to do- they were going to charge me a total of $133 rounding + $7 for clamps.
Might have to buy new detent cable. Been starting and running every time. Figured I had better fix oil leak. Old intake gasket appeared to have been leaking vaccum also. 194,000 and still going!
Suggested Repair
On the DIS ignition system, test the coil packs and ignition control module. One coil had an open secondary circuit; replacing all three coil packs and the module restored starting and running. These parts commonly fail from heat where they are mounted.
Conversation Summary
A 1990 Chevrolet Celebrity 3.1 EFI would not restart when warm, ran roughly in cool conditions, and later died while driving. OBD-I only flashed code 12. Spark looked weak and yellow. The owner found an open secondary on the coil for cylinders 2 and 5, then replaced all three coil packs and the ignition module. The car started and ran afterward. An expert noted these parts often fail from heat. The owner later replaced a leaking intake manifold gasket and made temporary vacuum-line and detent-cable repairs.
