1989 Chevy Celebrity Hot No-Start
REDANT
89 Chevy Celebrity 2.8 130000 miles: After driving in stop and go traffic for 30 to 40 minutes when I try to start the car it wont start. Ive had a gentleman help by tapping the starter a couple of times and then the car starts. This happens mostly during the summer months in Las Vegas Nv. The Radiator,hoses and cap are new and the temp guage doesnt get above 220. Before replacing the starter what else could be causing this problem?
Apr 28, 2007 at 2:40 PM
2CARPRO JACK
  • 11,533 POSTS
Verify that there is 12 volts at the power lug (big one) and that you are getting 12 volts to the trigger (small wire) at the starter. If so then the starter is bad, which is why when you tap on it, the car starts. Bad spot in the motor, and will eventually not work at all.
Apr 29, 2007 at 1:39 AM
Suggested Repair
With the no-start occurring, verify 12 volts at the starter's large power lug and at the small trigger wire. If both have voltage, the starter is bad (a dead spot in the motor) and should be replaced; tapping it only works temporarily and it will eventually fail completely.
Conversation Summary
The owner of a 1989 Chevrolet Celebrity 2.8 says it will not restart after 30 to 40 minutes of stop-and-go traffic, mainly in summer heat. Tapping the starter lets it start. The radiator, hoses, and cap are new, and the temperature gauge stays at or below 220. The expert advises checking for 12 volts at the starter power lug and trigger wire; if voltage is present, the starter is faulty and will eventually stop working altogether.
