1988 Chevy Celebrity Rear Wheel Wobble
SLYGUY0023
1988 Chevy Celebrity 2.5L Auto 206,000. Rear wheels wobble at 30MPH plus. Causes whole car to shake at speeds greater than 50MPH. All lugnuts tight. Not from a dead stop but, when the car is moving, if turning it sounds as if a paint can is in the trunk. Right wheel wobbles more than left.
Oct 18, 2007 at 8:42 PM
2CARPRO JACK
  • 11,533 POSTS
Could be the tires seperating, wheel bearing, or bent rim/rims
Oct 19, 2007 at 4:33 AM
Suggested Repair
Inspect the rear tires for separation, check the wheel bearings, and inspect the rims for bends, especially on the right side.
Conversation Summary
The owner of a 1988 Chevy Celebrity reports rear-wheel wobble above 30 mph that shakes the whole car above 50 mph. Lug nuts are tight, the right wheel wobbles more than the left, and a paint-can-like noise is heard in the trunk when turning while moving. The expert suggested possible tire separation, a wheel bearing problem, or bent rims.
