1986 Chevy Celebrity stalls
MIGUELKAT
  • 1986 CHEVROLET CELEBRITY
  • 4 CYL
  • FWD
  • 600,000 MILES
When I put the car in gear it stalls sometimes. Also, when I make a sharp turn while going slow, it stalls.
Monday, January 19th, 2009 AT 9:42 PM
KEVIN12881
  • 336 POSTS
Sunds like a loss of power issue. Are you up yo date with routine maitanence? Try SOME of the following Engine lacks power. See one of the following: 1.) Incorrect ignition timing. 2) Fuel filter clogged and/of impurities in fuel 3) Faulty or incorrect gapped spark plugs. 4) Air filter dirty. 5) Spark timing control system not working properly. 6) Faulty ignition coil(s) 7) Brakes binding. 8) Auto Trans fluid not correct 9) faulty distributor cap or wires 10) EGR system not functioning properly. 11) Use of sub standard fuel. 12) Low or uneven cylinder compression pressures 13) Air vacuum leak at intake manifold or plenum
Donate a few bucks fr a pro to help
Monday, January 19th, 2009 AT 9:51 PM
