1986 Chevy Celebrity stalling
SUNSTATEMECH
  • 1986 CHEVROLET CELEBRITY
  • 6 CYL
  • FWD
  • 95,000 MILES
I have an 86 Chevy Celebrity, it seems to run fine but when you take off from a stop it acts like it is going to stall, unless you put your foot to the floor. I have replaced the fuel pump, cap and rotor, checked the filter(could only find one) and fixed a couple broken vacuum lines. Could my problem be in the carb?
Saturday, April 10th, 2010 AT 2:09 PM
Inspect and test all the following listed below and get back with some results
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
Saturday, April 10th, 2010 AT 2:46 PM
