If the rod bearing hasn't spun in the rod then you can just get what they call a crank kit at a good auto parts store. You will have to pull the engine to put this in right. You can pull the pan in the car and find out if the rodbearing has spun. Look for the rod that moves the most on the crankshaft.
SPONSORED LINKS
Tuesday, October 13th, 2009 AT 1:00 PM
