1985 Chevy Celebrity no fire
100,000 MILES • 6 CYL • FWD • AUTOMATIC
SGT.1
i have 85 chevey celebrity 2.8L im getting no fire
first i replaced the ign coil and it started then broke down agin then i had the ecm tested and it tested good then i replaced the pickup coil it started and broke down agin i replaced the dis cap and roder and still nothing so i went back with a test light and tested the ign coil its getting power i tested the pickup coil for restiance and that was good and still no fire any ideas?
Feb 24, 2009 at 9:25 AM
JDL
  • 16,098 POSTS
Hello, is the coil in the cap? Did you use the test lite on the tach terminal at the cap? With the engine cranking, the lite should pulse? Does the tach terminal give an rpm reading?
Feb 24, 2009 at 11:11 PM
SGT.1
no the coil is not in the cap and it doesn have crank or cam position sensors
Feb 25, 2009 at 4:40 AM
SGT.1
but yes i did get a pulse from the coil
Feb 25, 2009 at 4:43 AM
JDL
  • 16,098 POSTS
Hello, you may have to use a tach, to make sure there is an rpm signal. If there is an rpm signal, the problem has to be either the coil wire, cap or rotor.
With the engine cranking, does the rotor turn?
Sorry i didn't post back sooner, my DSL broke down, couldn't get on the internet.
Feb 27, 2009 at 4:32 AM
SGT.1
i figured out the problem i have the ecm tested at autozone and they said it was good and after reading in the repair manual for about 3 days everything seemed to point to the ecm so i just decided to replace it any way and the car hasnt stoped running since go figure i hate going to autozone but it is the only parts store in my town thank you for your time though
Feb 28, 2009 at 9:51 AM
