1988 Chevy Celebrity Timming is off
1988 CHEVROLET CELEBRITY
120,000 MILES • 4 CYL • FWD • AUTOMATIC
BTHAIS
Not sure on what to do it sounds like the timing is off but is has a coil pack. We thought the timing had jumped so we broke it down redid the head had a valve job done it dont have a timing chain its gear on gear they looked good so we didnt replace them. we did check to make sure that part was lined up using the marks on the gears while it was top dead center that part looked good we got it all back together it still has a knocking but not as loud we think the timing been off is causing the knocking some what so how do we double check the timing with it having a coil pack
Nov 28, 2008 at 3:27 PM
DOCFIXIT
  • CAR REPAIR CONTRIBUTOR
  • 18,828 POSTS
Is knocking deep sound in engine like hammer? if so get under ues a long screw driver to your ear run along pan, block ect . see where it is loudest. Does knock go along with RPM? or more on rev up or under load?
Nov 29, 2008 at 11:15 AM
