2004 Chevy Cavalier Won't Start
THEMECH
i have a 2004 chevy cavalier with a 2.2.. with 193000 miles. it died and wouldn't start. fuel pressure was low so i changed the fuel pump and filter. still would not start. if you hold the throttle pedal to the floor it starts and then dies. checked the tps and it was good fuel pressure is good
Jun 9, 2007 at 7:34 AM
E40WATER12
  • 522 POSTS
Can u here the fuel pump kicking on, (buzz sound).
Also I would check to see if youre battery is fully charged, Also check to see if u have spark coming from one of youre plug wires, If not then, U got burnt out coil pack needing to be replaced.
Jun 9, 2007 at 10:44 AM
BPRICE443
  • 66 POSTS
I would get your car checked with a code reader even if the check engine light is not on because some codes willn't turn on the light. I suspect cam or crank sensor??
Jun 27, 2007 at 6:47 PM
Suggested Repair
Confirm the fuel pump primes, the battery is fully charged, and there is spark at a plug wire. If there is no spark, replace the coil pack. Also scan for stored codes and test the camshaft and crankshaft position sensors.
Conversation Summary
A 2004 Chevrolet Cavalier 2.2 with high mileage died and would not restart. Low fuel pressure led the owner to replace the fuel pump and filter, but it still only starts with the throttle held down and then dies. The TPS and fuel pressure now test good. Replies recommend confirming pump prime, battery charge, and spark, replacing a failed coil pack if spark is absent, and scanning for codes that may indicate a cam or crank sensor fault.
