1996 Chevy Cavalier Front Squeak
CAVILER2003
1996 Chevy Cavailer, 150k mmiles, 2.2 engine I think. My problem is recently my car started making a strange sqeaking noise in the front of the car. It only happens when the car is on and still/ I dont hear it when its moving. I also think its coming from the right side. Any help would be awesome. Thanks!
Apr 13, 2007 at 12:32 PM
SERVICE WRITER
  • 9,123 POSTS
would you describe it as a chirping sound?
Sounds like a belt noise, if so. Can check it by spraying a little water on the belt while it is running and seeing if it stops....for a moment.
Apr 13, 2007 at 12:38 PM
Suggested Repair
Check the accessory drive belt for noise. With the engine running, spray a little water on the belt; if the squeak stops briefly, inspect or replace the belt.
Conversation Summary
The owner of a 1996 Chevy Cavalier reports a front squeak, possibly on the right side, only when the engine is running and the car is stopped. The expert suggests belt noise and recommends spraying water on the belt while running to see if the noise stops briefly.
