1995 Chevrolet Cavalier Grinding Start
CHEVROLET
MRCHILLZ
Hi..I have a problem with my 95 cavalier. About half the time when I start it, the engine will start to turn over but before the car has a chance to start, it stops turning over and I hear a grinding noise. Usually after several attempts I can get it started, but it's getting worse. I am a student and don't have very much money so I was hoping I could fix it myself, but I need to know what the problem is first.
Help! Please!!
Dec 29, 2006 at 2:10 PM
SERVICE WRITER
  • 9,123 POSTS
Sounds like the starter solenoid is retracting before it starts. The gear on the starter backs off and grinds on the flywheel. If it isn't taken care off, it will chew up the flywheel. Get a good starter- I like napa or usa brand myself. If your gonna get a cheap one, I would go to a junk yard first.
Good luck in your studies :)
Dec 29, 2006 at 2:16 PM
MRCHILLZ
Thanks so much for the responce..I'll go pick up a starter tomorrow, and with a little luck be able to change it without screwing something else up :)
Dec 29, 2006 at 4:38 PM
Suggested Repair
Replace the starter with a quality unit (NAPA or USA brand, or a junkyard starter rather than a cheap new one). The solenoid appears to retract before the engine starts, so the drive gear backs off and grinds the flywheel; delaying repair can damage the flywheel.
Conversation Summary
The owner of a 1995 Chevrolet Cavalier reports that about half the time the engine begins to crank, then stops and makes a grinding noise. It usually starts after several tries but is getting worse. The expert says the starter solenoid is retracting early so the starter gear grinds on the flywheel, and recommends a good starter soon to avoid flywheel damage. The owner plans to replace the starter.
