1991 Chevy Cavalier Won't Start
If the starter motor won't crank, I'd have to make sure the battery has a full charge and the charging system is ok. Next, I'd have to check wiring circuits at the starter. Any testing at the starter, make sure tranny is in park or neutral and the parking brake is set.
If it cranks good but won't start, have a helper crank it while you visually check for spark at the spark plugs. If you have spark everywhere, use a gage and check proper fuel pressure, also check for fuel injector pulse.
Your obd1 so you should be able to check some trouble codes, yourself. To check codes, use a jumper wire between the A & B terminals at the datalink connector. Turn key just till the dash lites come on, no further. Then the mil on the dash starts flashing, you count the flashes to get the codes. Your looking for two digit codes.
Suggested Repair
If it will not crank, verify a full battery charge and a good charging system, then check starter wiring with the transmission in park or neutral and the parking brake set. If it cranks but will not start, check spark at the plugs, fuel pressure, and injector pulse, and retrieve OBD1 codes by jumping datalink terminals A and B and counting the check-engine light flashes.
Conversation Summary
The owner of a 1991 Chevrolet Cavalier station wagon with about 188,795 miles said it wants to turn over but will not start, and had been told the fuel injectors or fuel pump might be at fault. The expert advised checking battery charge, the charging system, and starter wiring if it does not crank, and checking spark, fuel pressure, and injector pulse if it cranks but will not start. The expert also explained how to retrieve two-digit OBD1 codes with a jumper at the datalink connector.
