1991 Chevrolet Cavalier Bogs and Backfires
MAMATAZ
My beloved 91 Chevy Cavalier has 180k miles and lately when I step on the gas it bogs down & will occasionally backfire. I can hold the gas to the floor & barely get her to move more than 25-30mph then whatever the trouble is seems to correct its self & returns to normal only to bog down again. I'm hoping it's just that she needs a new fuel filter...
Jul 2, 2007 at 1:52 PM
E40WATER12
  • 522 POSTS
Has the car had a tune up recently?. How old is the fuel & air filter?. Also I would get youre fuel pressure test done?. Could also have clogged CAT Converter,
Also coil packs could be pushing weak current.
Good Luck.
Jul 2, 2007 at 7:59 PM
Suggested Repair
Check whether a recent tune-up was done, inspect the age of the fuel and air filters, and test fuel pressure. Also consider a clogged catalytic converter and weak coil packs.
Conversation Summary
The owner of a 1991 Chevrolet Cavalier with 180,000 miles reports bogging, sluggish acceleration, and occasional backfiring that sometimes clears and then returns. The expert recommends checking the tune-up, fuel and air filters, fuel pressure, a possible clogged catalytic converter, and weak coil packs.
