1998 Chevrolet Cavalier Sluggish Acceleration Fix
TRACEY0508
1998 Chevy Cavalier, 117,000 miles, 2.2, My problem is this: When cold, the car works pretty good. It used to take awhile for engine temperature to reach normal heat (mid-range), but now it only takes about 5 minutes of running for it to reach the half-way point, and it doesn't get any higher. The hotter the car gets, the more sluggish it gets. When at a complete stop, if i push the pedal all the way down, it backfires. Once it reaches about 25-30, it runs okay, but you can still tell that it isn't running smoothly. When at idle, it is a rough idle. A friend's husband has been working on this car for about 6 years and he's checked everything. There is no error lights that are coming on. He's changed the spark plugs, wires, checked the air filters, fuel filters, compression is good, there are no clogs anywhere that he can find. He's suspecting the timing chain and will check it out this weekend, do you have any suggestions what the problem could be? Thanks for your website...it's great! :D
Jun 28, 2007 at 8:32 AM
E40WATER12
  • 522 POSTS
Sounds like u need youre coil packs either tested, Or replaced. Also I would replace youre thermostat and coolant temp sensor, See if that corrects anything.
Jun 28, 2007 at 9:27 PM
TRACEY0508
1998 Chevrolet Cavalier, 117,000 miles; I forgot to indicate in my e-mail yesterday - the coils were replaced the week before. Also, the muffler sounds louder.
Jun 29, 2007 at 1:39 AM
NICKN
  • 69 POSTS
get your catalitic converter looked at.
Jul 2, 2007 at 11:43 AM
TRACEY0508
Got the car fixed - the timing chain skipped two chains, and it now works like a champ! Thanks!
Jul 3, 2007 at 1:04 AM
NICKN
  • 69 POSTS
has that fixed the loudness of your vehicle? and im glad that it makes ur car run and drive better
Jul 10, 2007 at 11:21 AM
TRACEY0508
Yes, the car works and sounds like a charm! No noise whatsoever...
Jul 11, 2007 at 2:05 AM
NICKN
  • 69 POSTS
good to hear!
Jul 12, 2007 at 6:55 AM
ATOALVIS
My car is doing the same thing... Was your main issue the timing chain? because mine does it off and on and in the same ways yours did as well.
May 11, 2016 at 5:58 AM
Suggested Repair
The confirmed fix was a jumped timing chain (reported as skipped by two links). Inspect and correct or replace the timing chain. Coils had already been replaced; thermostat, coolant temperature sensor, and catalytic converter were also suggested but were not the final fix.
Conversation Summary
A 1998 Chevrolet Cavalier with 117,000 miles ran well when cold but became sluggish and rough as it warmed, with backfiring from a stop and a rough idle. No warning lights were present. Plugs, wires, coils, filters, and compression had already been checked or replaced, and the exhaust sounded louder. Experts suggested coil packs, the thermostat, the coolant temperature sensor, and the catalytic converter. The owner later reported the timing chain had skipped and that correcting it restored smooth running and quiet exhaust.
