2002 Chevrolet Cavalier Serpentine Belt Fix
DRUGDEAD
How do I change the serpentine belt on a 2002 chevy cavalier 2.2 L
Jun 27, 2007 at 4:34 PM
E40WATER12
  • 522 POSTS
First u need a long breaker bar to pull the tension off the belt tensioner, Once thats done the belt should pop off, Then re-install reverse from unstall.
Jun 28, 2007 at 9:33 PM
SHARK11
I just did this yesterday- 9/6/07 -thought I'd add some more for anyone else who might ask the same.
Raise the car, and remove the right-front wheel -
makes it' easier to reach the tensioner from underneath.
Use a 3/8" drive breaker bar to release the tensioner pressure/tension.
Sep 7, 2007 at 2:52 PM
Suggested Repair
Raise the car and remove the right front wheel for access. Use a long 3/8-inch drive breaker bar to release the belt tensioner, remove the serpentine belt, and reinstall it in reverse order.
Conversation Summary
The owner asked how to change the serpentine belt on a 2002 Chevrolet Cavalier 2.2L. Replies said to use a long breaker bar, preferably a 3/8-inch drive, to release the tensioner so the belt can come off, then reinstall it in reverse. One person added that raising the car and removing the right front wheel makes the tensioner easier to reach from underneath.
