2001 Chevy Cavalier Belt Comes Off
SAVOICE83
I have a 2001 Chevy Cavalier, 97000 miles on a 2.2lt. When driving the car the belt will come off the pulleys and the engine will overheat. Not sure which happens first. What should I do?
Aug 2, 2007 at 2:11 PM
SERVICE WRITER
  • 9,123 POSTS
The belt coming off happens first. When it does the waterpump is not spinning causing the overheat......Which can cost major bucks if there isn't already damage done. Whelie the belt is off, you need to turn each pully and feel for any looseness. The tensioner may be the likely culprit, bur you need to check.
Aug 2, 2007 at 2:47 PM
Suggested Repair
With the belt off, turn each pulley and feel for looseness. The tensioner is a likely cause, but all pulleys should be checked. Belt loss stops the water pump and can cause overheating damage.
Conversation Summary
The owner of a 2001 Chevy Cavalier with a 2.2L engine and 97,000 miles reports that the belt comes off the pulleys and the engine overheats. The expert says the belt comes off first, stopping the water pump and causing the overheating. Each pulley should be checked for looseness, with the tensioner a likely culprit.
