2002 Chevrolet Cavalier Fuel Pump Replacement Fix
RATBOY
2002 cavalier 2.2 (96213 mi.)how do you replace fuelpump
Jul 10, 2007 at 3:26 PM
E40WATER12
  • 522 POSTS
First thing I would do, Is buy an haynes repair manual, Then for the start of remove the pump, You need to remove all the rubber lines & metal lines from the gas tank, Be care full if youre gas tank is full of gas, I would get Some jack stands, Then with a floor jack with piece of plywood, To place on the floor jack, So when you are ready to undo the 2 straps that hold the gas tank, U have something to lower it onto the ground with. Undo the all the rubber & plastic line from the sending unit above the fuel tank, before, pulling it off the floor jack. Then of course, U need, to remove the pump from the sending unit, Then install the reverse method, Also make sure u put in a brand new fuel filter, Once eveything is put back together, Make sure you prime the fuel system line, allowing the pressure to enter the fuel line.(Note not allow the car to start). While priming.
Good Luck.
Jul 14, 2007 at 8:44 PM
Suggested Repair
Support the vehicle safely, relieve fuel pressure, and lower the fuel tank with a floor jack and plywood after disconnecting the tank straps and fuel lines. Remove the pump from the sending unit, install the new pump, replace the fuel filter, reassemble in reverse, and prime the fuel system without starting the engine.
Conversation Summary
The owner of a 2002 Chevrolet Cavalier 2.2 asked how to replace the fuel pump. The reply recommended a repair manual and outlined lowering the tank after disconnecting the lines and straps, removing the pump from the sending unit, installing a new fuel filter, and priming the system before attempting to start the car.
