RUSSBOLIN
Engine Mechanical problem
1990 6 cyl Front Wheel Drive Automatic
the car will run only on starting fluid, replaced fuel pump and getting 43lb pressure, could it be the fuel regulator
Aug 17, 2008 at 8:06 AM
  • 75,988 POSTS
Wrong fuel pressure and injector/s not pulsing
Do you have to feed it constantly with starting fluid to keep it running or hit it ones and run on its own?
Aug 17, 2008 at 9:06 AM
RUSSBOLIN
no it will only run while spraying, it will die as soon as you take the can away
Aug 18, 2008 at 12:08 AM
  • 75,988 POSTS
You need to check if the injector/s are working-opening and closing
Aug 18, 2008 at 8:41 AM
RUSSBOLIN
no the injectors are not opening,what module runs the injectors and where would it be located on this 1990 3.1 engine
Aug 18, 2008 at 9:55 PM
  • 75,988 POSTS
Check for power at the injector/s harness power there-the computer ground drivers are inoperative-
Aug 19, 2008 at 6:01 AM
RUSSBOLIN
yes i do have power on both wires going in to the injectors, but i held the test light on each wire while cranking and no pulsating. i really need to get this fixed . thank you
Aug 22, 2008 at 12:03 AM
  • 75,988 POSTS
When cranking engine over do you hear the injector/s clicking -if not its not pulsing could be a dead injector/computer ground drivers.
Aug 22, 2008 at 7:34 AM
RUSSBOLIN
what are the computer ground drivers you keep refering to , could be a bad injector but probably not all 6 of them
Aug 22, 2008 at 8:47 AM
