Fuel pump
TRACYNAKAI
  • CHEVROLET CAVALIER
I have a 2004 Chevy Cavalier, where is the location of the fuel pump? I need instructions on how to remove and install new pump.
Friday, November 30th, 2007 AT 10:10 AM
BLACKOP555
  • 10,371 POSTS
It is located in the fuel tank, it may be located on the side of it or the top, if it is on the top you can drop the tank and take off the retaining ring and pull the pump out.
Some cars have an access you can get to in the trunk.
Here is a guide to help you see what you are in for when doing the job.
https://www.2carpros.com/articles/how-to-replace-an-electric-fuel-pump
if its on the side you do not have to drop the tank and you can take it out by removing the retaining ring.
Friday, November 30th, 2007 AT 12:10 PM
