2000 Chevy Cavalier Driver Wiper Stops
ADEVAL
2000 Chevy Cavalier with 80,000 miles on it, 2.2L engine.
Turned on windshield wipers and the passenger side one works fine. The drivers side wiper moves a tiny bit and then stops. I live in Arizona so we don't use the wipers alot but we did have a freeze a couple nights ago and wipers were frozen to windshield. Could this have damaged the one somehow or is it a fuse or something else?
Thanks!
Jan 30, 2007 at 7:52 AM
SERVICE WRITER
  • 9,123 POSTS
Pry off the plastic cap at the base of the arm. There is a nut there. remove it, remove the arm. Clean any crap that may be in there and inspect it for any excessive wear. Reseat the arm if the grooves that prevent slippage are still intact and tighten the nut down solidly. Put the cap back on. Turn it on to test it. Go relax with a favorite beverage and feel good for making the day worthwhile :D
Jan 30, 2007 at 9:52 AM
Suggested Repair
Remove the driver-side wiper arm cap and nut, take off the arm, clean the mounting area, and inspect the anti-slip grooves for wear. If the grooves are intact, reseat the arm and tighten the nut securely, then test the wipers.
Conversation Summary
A 2000 Chevrolet Cavalier owner reported that the driver-side windshield wiper moved slightly and then stopped while the passenger-side wiper worked normally. The wipers had recently frozen to the windshield. The expert advised removing the arm, cleaning and inspecting its mounting grooves, then reseating and firmly tightening it if the grooves were intact.
