1997 Chevy Cavalier Wipers
WISNERD
Engine Mechanical problem
1997 Chevy Cavalier 4 cyl Two Wheel Drive Automatic
I recently replaced the wiper motor on my 1997 Chevy Cavilier. When I turn them on they will run once then not work again unless the car is turned off. I then restart the car they may or may not go once then will not go again. If I continue to play with them they will run but then again only one time up and will not again unless the power is turned off. Is this a faulty motor? I replaced the fuse too.
Apr 30, 2008 at 12:42 PM
RHALL77
  • 3,361 POSTS
compare the part numbers. you may have the wrong wiper module or a bad wiper switch. does yours have a wiper delay. because if yours does and the module doesnt have the opition, that could cause it.
May 2, 2008 at 2:04 AM
