1997 Chevrolet Cavalier Oil Light at Idle
WILLDAVIS
I have a 97 cav 2.2L with about 119,000 miles and I am having problems with the check oil light. When ever I drive the car and get it to opreating temp the check oil light comes on when ever the engine is idling. But as soon as the engine is above idle the light goes out. Any ideas?????
Jun 27, 2007 at 9:19 PM
E40WATER12
  • 522 POSTS
First I would check youre oil level, If that checks out good, Then I would take a look at youre oil pressure sending unit, Its either leaking or broken, Needs replacing.
Good.
Jun 28, 2007 at 9:31 PM
Suggested Repair
Check the oil level first. If the level is correct, inspect the oil pressure sending unit for leaks or failure and replace it if needed.
Conversation Summary
A 1997 Chevrolet Cavalier 2.2L with about 119,000 miles shows the check oil light at idle once the engine reaches operating temperature, and the light goes out above idle. The expert advised checking the oil level first, then inspecting the oil pressure sending unit, which may be leaking or broken and need replacement.
