2002 Chevrolet Cavalier Overheats at Idle
MMORELOC21
2002 Cavalier stickshift 84,000 miles 4cyl.
Car overheats while sitting still, cools down when moving. A/C blows hot air when idling, works when moving.
Sep 22, 2007 at 2:47 AM
  • 75,988 POSTS
[quote:9c4c06aa37="mmoreloc21"]2002 Cavalier stickshift 84,000 miles 4cyl.
Car overheats while sitting still, cools down when moving. A/C blows hot air when idling, works when moving.[/quote:9c4c06aa37]
Check the thermostat and report back your findings.
Sep 22, 2007 at 3:40 AM
MMORELOC21
[quote:3ed12ec0b6="rasmataz"][quote:3ed12ec0b6="mmoreloc21"]2002 Cavalier stickshift 84,000 miles 4cyl.
Car overheats while sitting still, cools down when moving. A/C blows hot air when idling, works when moving.[/quote:3ed12ec0b6]
Check the thermostat and report back your findings.[/quote:3ed12ec0b6]
My thoughts was the same until I noticed the cooling fan wasn't working. After checking wires I eventually found the relay and it was bad. I replaced it and it seems to have corrected the problem. Thanks for your help.
Sep 26, 2007 at 5:05 PM
Suggested Repair
Check the thermostat, then verify cooling-fan operation and the fan relay. In this case, a failed cooling-fan relay was replaced and corrected the overheating.
Conversation Summary
A 2002 Chevrolet Cavalier overheated and the A/C blew hot air while idling, but both improved while moving. The expert suggested checking the thermostat. The owner then found the cooling fan was not working because of a bad relay; replacing the relay corrected the problem.
