1997 Chevrolet Cavalier No Power
LSDAVIS
I have a 1997 Cavalier and every time I try to accelerate especially going up hill it seems like its not getting gas and skips but if I let off the gas and then press it again it is fine and also when I slow down to make a turn and start to accelerate it like it has no power. I have recently replaced the fuel filter and thought that had solved the problem but the check engine light and the ETS off ligts keep coming on periodacally. They'll go off for a day and then come back on. I was going to replace the spark plugs and wires to see if that would help or I thought maybe it might be the oxygen sensor. Any advice would be much appreciated.
Oct 2, 2007 at 7:22 AM
MERLIN2021
  • 17,250 POSTS
Can you get to an Autozone and have the codes read? They do it free, then post the codes here, Your symptoms are more like a converter that has broken up inside, and the pieces are choking the engine off!
Oct 2, 2007 at 7:34 AM
Suggested Repair
Have the check engine codes read for free, then inspect the catalytic converter. A broken converter can restrict exhaust flow and cause the power loss, especially under load.
Conversation Summary
A 1997 Chevrolet Cavalier loses power and skips when accelerating uphill or after slowing for a turn, then runs better if the throttle is released and reapplied. The fuel filter was replaced, and the check engine and ETS Off lights come on intermittently. The owner considered plugs, wires, or an oxygen sensor. The expert advised reading the codes and said the symptoms fit a catalytic converter that has broken apart internally and is choking the engine.
