Hub Bearing Replace?
CHEVROLET CAVALIER
KCAMPBELL1
I have a '98 Chevy Cavalier and I'm told that the hub bearing is cracked. My repair person also told me that if I didn't fix it immediately, I could risk damage to the tire, and being stranded on the side of the road. How dire is it to get a bearing replaced? Am I really risking a tire flying off in traffic as my repair person would have me believe? Any idea on a cost estimate?
Thanks!
Feb 1, 2007 at 7:07 AM
BOOTDOG
  • 665 POSTS
GM hub bearings are pretty easy to fix. is it the front or rear? i know that they are a bolt in design. let me know if it is the front or rear so i can give you instructions on replacement.
Feb 2, 2007 at 11:40 AM
CLEAVAGE4U
  • 69 POSTS
Sweethart? is the bearing making a noise?
How all did you discover it?
Daddy says those NEVER crack, He thinks y'all are getting fleeced. The Bearings gonna get pretty darn bad a fore it comes apart. I bet if you stick with Mr. Bootdog, he'll teach y'all a new trick.
I think I'd get a second opinion on that or maybe Mr. Houndfoot can tell ya how ta check it first.
Maybe you'll even give him a reputation for it
Feb 2, 2007 at 11:58 AM
KCAMPBELL1
You guys are all too funny. I appreciate all the feedback and advice - unfortunately I'm used to service repair techs assuming that I won't be smart enough to ask questions and get second opinions before getting work done.
This would be the driver's side front bearing that's making the noise. I noticed it about a month ago, when if I'm on the freeway, I'll hear a grinding sound when I turn left, but it goes away when I turn right. About the same time, my ABS brake light would start coming on when I turned left as well. My brother suggested it was a bearing issue, and then my service repair person said the same thing.
Thanks for the help!
Feb 5, 2007 at 3:29 AM
SERVICE WRITER
  • 9,123 POSTS
Sounds like the the bearing to me by your description. A couple ways to nail it down. First have the codes pulled from the computer, good chance it will point to the problem child or children if both are a problem. Second, it too raise the front end so the wheels are off the ground, run the motor until the speedometer hit 30 mph and hold it. You may be able to hear which wheel is the noisy one. May need a stethoscope and may need to prevent one wheel at a time from spinning while checking this. My preference is a Timken brand wheel bearing/hub assembly.
https://images.2carpros.com/forum/automotive_pictures/30961_wb_1.jpg
Here is a video for the style of repair https://youtu.be/ZgiPRG6jffc
Feb 5, 2007 at 9:16 AM
BOOTDOG
  • 665 POSTS
also one other way, while the wheels are of the ground, place your hand on the strut spring and spin the tire. if you feel vibration through the spring, then that is the side that is bad. hope this helps :D
Feb 5, 2007 at 10:15 AM
SERVICE WRITER
  • 9,123 POSTS
COOL....Never knew that! Those service writers!
Feb 5, 2007 at 10:24 AM
