1994 Chevrolet Cavalier Starter Grinding
GMC
CHINSY2000
  • 6 POSTS
I have 1994 Chev Cavalier 2.2L :cry: and i have replace a number of starters in it over the last 3 years the last one i replaced is a champion rebuild from canadian tire the others were ones from a scrap yard. my question to way i am going through them so quick the rebuilt one is still in but it is making a bad grinding noise when starting when i changed it, it had two shims are there to be two. Thanks
Jan 20, 2006 at 7:52 AM
SC1 RACING
  • 117 POSTS
you will need to shim each starter. not all starters end up being shimed the same. easy way to do it is get a steel coat hanger straighten a pc, and you wont it to just fit between fly wheel teeth, and starter teeth. also check batt connection and grounds. oil leaks and heat will also kill a starter prematurally.
Jan 20, 2006 at 8:00 AM
Suggested Repair
Shim each starter individually so a straightened coat-hanger wire just fits between the flywheel teeth and starter teeth. Also check battery connections and grounds, and correct oil leaks or excess heat that can shorten starter life.
Conversation Summary
A 1994 Chevrolet Cavalier 2.2L owner has replaced several starters in three years. The current rebuilt starter grinds when cranking and was installed with two shims. The expert says each starter needs its own shim setting, recommends checking tooth clearance with a straightened coat hanger, and also checking battery connections, grounds, oil leaks, and heat.
