WHAT"S INVOLVED AND HOW LONG WOULD IT TAKE TO REPLACE A FRONT WHEEL BEARING ON A 1996 CHEVY CAVALIER WITH 225,000 MILES?[/b]
Aug 16, 2006 at 11:10 AM
Replace the front hub and bearing as an assembly. Raise and support the vehicle, remove the wheel, axle nut, and ball joint, separate the axle from the hub, support the caliper, remove the rotor, and unbolt the hub and bearing. Install the new assembly and torque the fasteners and a new axle nut to specification. Labor time was not stated.
The owner asked what is involved and how long it takes to replace a front wheel bearing on a 1996 Chevy Cavalier with 225,000 miles. The expert provided hub-and-bearing removal and installation steps, including separating the axle, supporting the caliper, and torquing fasteners to specification, but did not give a time estimate.
