1999 Chevy Cavalier Coolant Loss
CALIGRL59
I have a 1999 Chevy Cavalier about 116,700 miles with automatic transmission. I just got the car and noticed the coolant level was low so I refilled it. It leaked out at first because I did not notice I had a defective radiator cap so I replaced the cap and put in coolant again since it was empty again. I thought that was the problem because I haven't noticed a leak, but within a day it was empty again. Is it possible its leaking and I don't see it? Or is there something wrong with the radiator? About how much does it cost to fix if it is a radiator problem?
Oct 14, 2007 at 4:16 PM
BOOTDOG
  • 665 POSTS
sounds to me the radiator was very low, when refilling the radiator, run the engine to allow the thermostat to open then top it of again. continue to let it run until the engine fan cuts on. top it of, cap the radiator, and top off the reservoir.
Oct 15, 2007 at 9:21 AM
Suggested Repair
Refill the low radiator with the engine running so the thermostat can open, then top it off again. Continue running until the cooling fan comes on, top off once more, install the radiator cap, and fill the reservoir.
Conversation Summary
The owner of a 1999 Chevy Cavalier with about 116,700 miles refilled low coolant, replaced a defective radiator cap, and found the system empty again within a day. They asked whether an unseen leak or radiator problem could be responsible and what a radiator repair might cost. The expert said the radiator was likely very low and advised running the engine during refill until the thermostat opens and the fan comes on, then topping off the radiator and reservoir.
