2004 Chevrolet Cavalier Clutch Pedal Floor Fix
LILACSCANDAL
Help please. I need to fix this. I am very handy and it sounds like its not a bad problem...but I am financially strapped. the clutch pedal goes to floor and will not engage. Its not just sticking because when you physically pull it up it stays, but it is disengaged and wont go into gears.
PLEEEEZZZZE. Thank you :(
Aug 25, 2007 at 7:56 AM
BOOTDOG
  • 665 POSTS
check the linkage from the pedal to the the transmission. if it looks ok, nothing broke or binding, then something in the pressure plate broke, as a result the clutch will need replacing.
Aug 27, 2007 at 1:36 AM
Suggested Repair
Inspect the clutch pedal-to-transmission linkage for breakage or binding. If the linkage is intact, a failed pressure plate is likely and the clutch should be replaced.
Conversation Summary
The owner of a 2004 Chevrolet Cavalier says the clutch pedal drops to the floor and will not engage. Pulling the pedal up leaves it disengaged, and the transmission will not go into gear. The expert advises checking the pedal-to-transmission linkage; if nothing is broken or binding, the pressure plate has likely failed and the clutch needs replacement.
