2004 Chevrolet Cavalier Shifter Moves Freely
SEXIILILBABI09
i have no idea what is wrong but i have a 2.2 eco-tech 4 cyl. and i was driveing it in town and i went to shift gears but the gear shifter wouldnt shift it just moves around freely and i called the dealer where i got it and my warranty ran out so i have to fix it myself because i dont have the money to pay for a garge to fix it.. can somebody please help!!
The shifter just moves around freely and wont go into gear and the cluth is fine it has pressure.
PLEASE HELP!
Oct 9, 2007 at 8:29 AM
SERVICE WRITER
  • 9,123 POSTS
Sounds like the shifter cable broke. You'll need to remove the center console and get a closer look to see what you have. You'll need a manual to get the removal and adjustment procedures. It's a little long to describe.
https://www.2carpros.com/kpages/auto_repair_manuals.htm
Oct 9, 2007 at 11:49 AM
Suggested Repair
Inspect the shifter cable, which may be broken. Remove the center console for a closer look and use a repair manual for cable removal and adjustment procedures.
Conversation Summary
The owner of a 2004 Chevrolet Cavalier with a 2.2 Ecotec four-cylinder reports that the gear shifter moves freely and will not select gears, while the clutch still has pressure. The warranty has expired. The expert says the shifter cable may be broken and recommends removing the center console to inspect it, using a manual for removal and adjustment.
