94 Cavalier Z-24 5 speed clutch problems
RSOUKUP37
  • 1994 CHEVROLET CAVALIER
I have a 94 cavalier racecar and I was driving around the track and went to downshift two second and had no clutch pedal. So I looked under the car and I saw fluid shooting out when you hit the pedal and I believe its either the slave or master cylinder. I was wondering if you had to drop the trans to change whatever I have to fix I could still run the car but it was really hard to shift due to power shifting into gear.
Saturday, July 7th, 2007 AT 9:20 PM
E40WATER12
  • 522 POSTS
U need to replace youre slave cyl, If youre clutch has no pressure. I think its 2or3 bolts, Take off the fluid line then then after putting on the new one, U need to bleed the new slave cyl. Then youre set.
Good luck.
Sunday, July 15th, 2007 AT 3:56 AM
