2005 Chevy Cavalier Clutch
95,000 MILES • 4 CYL • FWD • MANUAL
SERCOR1
My clutch went all the way down to the floorboard and stay there. I understand that when that happens is the slave cylinder that is bad. How do you replace it. Do you have a video that shows you how?
Jul 4, 2009 at 5:22 PM
BMRFIXIT
  • 19,053 POSTS
Are you sure its the slave!?!?!
check fluid and add if needed
slave or clutch actuator cylinder
is located inside the bell housing behind the clutch
Remove the transmission down and
Remove the clutch actuator cylinder bolts from the transmission.
good luck
Jul 4, 2009 at 11:28 PM
