white smoke, engine oil milky. head gasket doesn't seem to be broken or leaking after removing. what else could it be?
Jul 25, 2006 at 12:06 PM
Have the cylinder heads pressure tested and checked for cracks at a machine shop. Also inspect the intake gasket and identify the cleanest pistons as the likely breach area; a cracked block is less likely.
The owner of a Chevrolet Cavalier 3.1 reports white smoke and milky engine oil. After removal, the head gasket did not appear broken or leaking. The expert says possible causes include the intake gasket, head gasket, a cracked cylinder head, or less likely a cracked block, and recommends machine-shop pressure testing of the heads plus checking which pistons are cleanest.
