1989 Chevy Cavalier Oil Pressure Drops
ROOHEAD
I have a 1989 chevy cavalier z24 with a 2.8 liter engineon 125,000 miles.We changedthe oil,spark plugs and wires. I now have a problem with my oil pressure guage when the engine is cold the guage is at half way but when the engine warms up it drops down to zero when i accelerate it goes up about a quarter of the way. What could cause this problem?
Jul 6, 2007 at 1:24 PM
BPRICE443
  • 66 POSTS
Have you changed to a different type of oil? Is the gauge electronic or mecanical? If the gauge is electronic check to see if you may have knocked the connection loose when changing the plugs?
Hope this helps
Jul 9, 2007 at 6:17 PM
ROOHEAD
We checked the connection but it is fine. The car runs fine so could it be anything else?
Jul 12, 2007 at 12:52 PM
  • 75,988 POSTS
[quote:e138d68400="roohead"]I have a 1989 chevy cavalier z24 with a 2.8 liter engineon 125,000 miles.We changedthe oil,spark plugs and wires. I now have a problem with my oil pressure guage when the engine is cold the guage is at half way but when the engine warms up it drops down to zero when i accelerate it goes up about a quarter of the way. What could cause this problem?[/quote:e138d68400]
Could be the gauge and its wiring,oil pump,and bad engine bearings.Do you hear a thumping noise at the lower end of the engine.
Jul 14, 2007 at 4:18 PM
ROOHEAD
no the engine is not making any noises at all.
Jul 14, 2007 at 10:40 PM
  • 75,988 POSTS
[quote:17ef2e384b="roohead"]no the engine is not making any noises at all.[/quote:17ef2e384b]
Okay, get an Oil pressure gauge, remove the oil sending unit, now monitor the pressure from a cold start to fully warm engine. This will tell you something.
Good LUck
Jul 15, 2007 at 1:10 AM
Suggested Repair
Install a mechanical oil pressure gauge in place of the oil sending unit and compare readings from a cold start through a fully warm engine. If actual pressure is normal, suspect the gauge, wiring, or sending unit. If pressure is truly low when hot, inspect the oil pump and engine bearings even if there is no knocking.
Conversation Summary
A 1989 Chevrolet Cavalier Z24 with a 2.8L engine and 125,000 miles shows oil pressure about halfway when cold, near zero when warm, and about a quarter of the way up when accelerating. Oil, spark plugs, and wires were recently changed, the engine runs fine, and there is no lower-end noise. The sending-unit connection was checked and found secure. The expert said the cause could be the gauge and wiring, the oil pump, or worn bearings, and recommended measuring actual pressure with a gauge from cold start to fully warm.
