1997 Chevrolet Cavalier Won't Start
SGIBB
I changed a leaking fuel injector in my 1997 cavalier and now it won't start. I'm sure everything is back together right and I purged the fuel line of air but it still seems as if its not getting gas. It turns over fine but will not start. Any ideas.
Feb 6, 2007 at 9:41 AM
BOOTDOG
  • 665 POSTS
sometimes things can go wrong after a repair is made and it has nothing to do with what was fixed. first of all go back and check your work thoroughly. if everything is ok then turn the key to the on position, (without starting it), and see if you hear the fuel pump cut on. if not tap on the fuel tank with a hammer while someone else tries to start it. if it starts, replace the fuel pump, if not then you'll need to find out if you have power to the pump. also check the fuel pump relay. hope the info helps :wink:
Feb 6, 2007 at 9:59 AM
Suggested Repair
Recheck the injector repair, then confirm the fuel pump primes with the key on. If tapping the tank while cranking makes it start, replace the fuel pump; otherwise check pump power and the fuel pump relay.
Conversation Summary
A 1997 Chevrolet Cavalier will not start after a leaking fuel injector was replaced, even though it cranks and the fuel line was purged. The expert advised rechecking the repair, listening for the fuel pump with the key on, tapping the tank while cranking, and checking pump power and the fuel pump relay if it still will not start.
