I own a 97 Chevy Cavalier RS with 129,000 miles on it. It has a 4 cylinder engine and 2 wheel drive with an automatic transmission. It has started stalling right after I start it. Also, while I am at a stop light it idles rough...for example the whole car will shake. And at times I will hit the gas pedal and the engine will not accelerate as quickly as it should, like ti takes a second to realize I hit the gas pedal. I have replaced the fuel filter, and the crank position sensor, also the alternator and the battery are new and I believe the plugs and wires are new within the last 2 years Help!!! My mechanic apparently is not so bright because he said he can't get it to act up.
Jul 21, 2007 at 6:20 AM
