Car does while stopped
SPICE9195
1997 Cavalier, 117,000 miles 2.2L automatic Car will start ok but if I don't get in gear and drive quick enough it will die. If I get it going I could drive forever with no problem but when I get to a stoplight and make a complete stop it will die. It makes no noises like when an engines dies, it just does. When I bought the car last year it needed something called an EGR valve but I never had any problems so I didn't replace it. Had the engine light read and it said that again and something about an Idle air control. Which one of these will make the car die? The Autozone guy said the later and somebody else says the EGR valve.
Jun 10, 2007 at 5:04 PM
E40WATER12
  • 522 POSTS
well u you got the trouble code scanned and its the EGR valve, Thats the part needs to be replaced.
Jun 10, 2007 at 5:39 PM
LDREUSSER
My car is experiencing the exact same thing! No one seems to have an answer. Did you determine the cause yet? I would appreciate any information! ;-)
LD
Jun 19, 2007 at 10:58 AM
BPRICE443
  • 66 POSTS
The EGR valve will cause those symtoms and so will the ide speed motor. I would replace the bad parts and you should be fine
Jun 25, 2007 at 7:07 PM
