1995 Chevy Cavalier Brake Bleed
VOIGT1
how do i bleed the breaks on a 95 chevy cavalier
Jul 1, 2007 at 2:44 PM
E40WATER12
  • 522 POSTS
Well you are gonna need another friend to help you with this, First jack up the car, You are gonna need a few cantainers of 3 Dot brake fluid, Then on the front front brake calipers, There is a little bleeder screw, Use a 10mm socket on a ratchet, Make sure its set to counter clock wise selector, If not u will snap the bleeder screw, Once u loosen the screw, Tighten it back up, get a buddy to pump the brake pedel, with the bleeder screw tighten, Then after the brakes pump 3 times, get youre buddy to hold them to the floor, Then u undo the bleeder screw, U should see the brake fluid pouring out, Youre buddy should feel the pressure of the pedel going to the floor, 3 times bleeding each tire will do for the system to get the air out of youre brake system. Also just make sure u keep an eye on the level of the brake fluid, If it gets to low u will have to re bleed the system again.
Good Luck.
Jul 2, 2007 at 8:19 PM
Suggested Repair
Bleed the brakes with a helper using DOT 3 fluid. Jack the car up, loosen each caliper bleeder screw carefully with a 10 mm socket, then retighten it. Have the helper pump the pedal three times and hold it down while you open the bleeder to release fluid and air, then close it. Repeat about three times at each wheel and keep the reservoir from running low so air is not drawn back in.
Conversation Summary
The owner of a 1995 Chevrolet Cavalier asked how to bleed the brakes. The reply describes a two-person procedure: use DOT 3 fluid, carefully open and close the caliper bleeder screws, pump and hold the pedal while releasing fluid, repeat at each wheel, and monitor the fluid level so the system does not need to be bled again.
