1996 Chevy Cavalier Brake Pull
Keep us updated
Good Luck.
The way to test youre shocks to see if they are good, This is called bounce test, push with both hands on front of the car until see the car go towards the ground, If the car bounces more then once youre struts are worn, Also it makes be thing youre strut mount & strut bearings are wornout, They manke those kinds of noises, Also strut mount & strut bearings are a common thing to wearout quick on these cars.
Good Luck.
Suggested Repair
Check rear brake shoes, tire pressure (about 32 psi), and front tire edge wear for an alignment issue. With the front raised, check ball joints for up-and-down play. Perform a bounce test and inspect strut mounts and strut bearings, which commonly wear on these cars and can cause clunks over bumps.
Conversation Summary
A 1996 Chevy Cavalier with a 2.2L engine pulls when braking: the steering wheel turns left and the front end pulls right, with a sudden bump noise under hard braking and a loud noise over heavy bumps. New pads and rotors did not fix it, and the owner found the front components solid. The expert advised checking ball joints, tire pressure, outer tire wear and alignment, and rear brake shoes, then suggested a bounce test and inspection of worn strut mounts and bearings as a common cause of the noise.
