2002 Chevrolet Cavalier Battery Light
RICHADKINS
2002 cavilier 2.2 new bat new alt the bat light coms on and off randomly. the dealer said it is a diode in alt but after checking the alt it is good new bat is good also what else should I check out? miledge is aprox.100,000 also has new belt.
Jun 10, 2007 at 7:44 AM
E40WATER12
  • 522 POSTS
Was the alt, A new one or Remanfactured one? I would also check youre battery cables, Also with youre car idling, I would run a digital meter tester to see if the charging current is functioning, I would be bet there is a problem with the electronics hardware inside the alt.
Good Luck.
Jun 10, 2007 at 11:24 AM
RICHADKINS
[quote="RichAdkins"]2002 cavilier 2.2 The alt. was reman. the parts stor checked it and it tested good at two dif. part stores
Jun 11, 2007 at 1:44 PM
Suggested Repair
Inspect the battery cables and connections, then measure charging voltage and current with a digital meter while the engine is idling. Even though the remanufactured alternator tested good at parts stores, its internal electronics may still be faulty.
Conversation Summary
A 2002 Chevrolet Cavalier 2.2 with about 100,000 miles has a battery light that comes on and off randomly despite a new battery, new belt, and remanufactured alternator. The dealer suspected an alternator diode, but two parts stores tested the alternator as good. The expert advised checking the battery cables and measuring charging output at idle, suspecting internal alternator electronics.
